Modification of the NA engine
rollakid
4,936
5
Kuching Sarawak
Andres said:
yalah, if really wan to increase HP in easy way is TURBO. BUt, the turbo car compare to our daily car the maintannace is more high? example like: fuel combustion , turbo kit spoiled, intercooler problem... etc. all also is only turbo car have... so??? pls advice
yes but that's only the case if you torture your car and not taking care of it properly.
turbo fuel consumption can be low if you don't rev it/lap all the time since if the turbo didn't kick in it uses way less fuel. Turbo will hardly spoil if you take good care of it and not abuse it. about the intercooler, i've not had any turbo car before, but the only problem i've heard about so far is those front mount i/c got damaged by flying chips of stones :D
Dino@Casper
666
P.J
Fuel comsumption is actually lower if u drive on highways and dun always floor.. intercooler problem all those can be solve with a good mechanic.. as long he knows what he is doing.. all this shouldn't have any problem
Honestly if u trash ur NA engine.. the bill would be just as bad as ur turbo car's repair bill man.. trust me been there..
bcteh
27
With this kind of mod, I would advice him to do engine transplant ....much cheaper.
rollakid said:
Here's a common way of upgrading an NA engine, although in a general way and not specific to any model and do not need to be strictly followed:
1. Good lubricant, less friction means more power.
2. Intake and exhaust, note that drop in filter is better for light mod since open pod/cone filter draws in hot air = less power, unless your car is for track racing where it move fast enough to ram cold air in your engine bay everytime or you can afford cold air intake system.
3. Adjustable cam pulley. can adjust for predictable power, but if you have variable cam timing, might as well leave it, better for everyday driving.
4. mild cams, extra power with stock ecu.
5. use lightened flywheel
6. go for aftermarket programable ecu, and throw in racing cam inside, as high as you can accept.
7. rebuild and balance the whole engine, do a 3 angle valve job or 5 angle one, port and polish the head.
8. do anything to increase your compresion ratio, but with malaysian's ron97 fuel i don't see too much increasement in power without suffering from knocking :D
thats about the general stuff you can do with your engine, other performance gain that do not have anything to do with the engine would be:
-use a good clutch system
-if you got the money and willing to learn, get a dog engagement gearbox
-use smaller size/lighter/balanced rim
-basically make your car have better power to weight ratio..
well, hope that helps...
Andres
118
Penang
to all sifu, u all said is correct also, but however, u can post all the modification regarding the turbo or NA engine modification, let all of us also can refer to!!! :tee:
rollakid
4,936
5
Kuching Sarawak
you mean transplat to a turbocharged engine? well yes, you can get all the power of the NA mod with a fraction of the cost by playing with turbo, but you will never get the satisfaction of squizing out every last hp out of that NA engine :D
how i wish there isn't any roadtax... so i can drive around in a 6 liter V8 everyday..
llsaw
195
Penang
thespfiles.blogspot.com
"8. do anything to increase your compresion ratio, but with malaysian's ron97 fuel i don't see too much increasement in power without suffering from knocking"
I don't have any problems running on local fuel with 11.9 compression. It's all in the mapping but some Afterburn helps too..
rollakid
4,936
5
Kuching Sarawak
yes i do know that, tho i've only heard about 11.5 before, so thanks for your info :D but you can't deny that having low octane fuel is robbing precious horsepower especially for NA engine.
V8_nutter
516
97 octane is low, suitable for on the road use only. If you have more than 11+ compression and high ignition, engine will knock like crazy.
rollakid
4,936
5
Kuching Sarawak
ron97 compare to US sure not low lar.. but compare to the rest of the more developped country sure on the lower side. me still dreaming of pumping 100 octane fuel in petrol station...
V8_nutter
516
If you're running 11.9 and engine is in "safe" condition meaning that your setup is "mild". Im running that compression wif avgas only, cause even V Power will knock like hell.
V8_nutter
516
If you feel 97 ron is OK, meaning your engine setup is mild.
i used awd fuel tank for last 3 years. but suddenly last month i noticed strong petrol smell appear at the backsde. the smell even worse when the tank almost empty, but if the tank full, the smell not too strong. i have checked an noticed no leaking at all. does anybody has experienced the same thing and how to overcome this problem.
(please help, because something play with petrol will be danger.):confused_smile:
