Mivec+Turbo Or 1.8GSR 4G93+Turbo
Rons
29
sg
jzhost said:
i dont think 1.6 2.0 is legal, they only allow 25% increase in cc, if can i wont get a 1.6 mivec from 1.3 engine la brother...
dont talk about paying undertable money, its still not legal
my experience, mivec turbo cost you alot... because mine is mivec turbo.
at 1st i get a mivec halfcut and install it, change semi clutch and service almost things, cost me more than 10k already
get a ems cost me 2.2k
install the turbo kit and cost me almost 5k
what you think?
thxs dude, for sharing ur mivec turbo experience..
kwai
1,891
12
Perak
what you think?
wow, so urs are 1.6 mivec turbo?
where u did it?
dynoed b4?
running on how many bar?
how's the reliablity?
jzhost
279
no dyno done yet, now run used to be at .9 bar with thai wastegate, changed wg to tial, now at .5
Penghanyut
123
22
1.6L to 2.0L is LEGAL. Car MUST go for inspection. :)
1300cc (just an assumption) x 1.25 = 1625cc.
obviously u dont have other choice than a 1.6L
pdguy
783
Everywhere
basically im interstedin MivecTurbo also ...... mine juz MIVEC loh :)
so do u mind tel me how is the activations ? im not wrong turbo 1st and 2nd mivec kicks in right ? So at wat rpm both kicks in ? and other interstin detals pls pls !
Thanks.
HyperRevved 6313
230
Cheras
Thanks.
There's no turbo and mivec separate kicks in if u bolt on turbo on mivec by using Microtech. Mivec lift together kicks in 2getha with turbo. If u really wanna bolt turbo on mivec get ready around 12-15k budget should be enuf .....
jzhost
279
cant say so...
let say if you activate your mivec means with a td04 kick in at 2.5k rpm with mivec, your car will scream like hell and you will suffer in higher RPM.
for my setting, mivec open as stock 5-5.5k rpm... so with this i enjoy boost come at 2.5k and all the way i still can rev up to 7k, after 7k will no feel at all... ofcause the g feel wont that much at high rpm
HyperRevved 6313
230
Cheras
jzhost said:
cant say so...
what ECU are u using ?
xerox0131
malaysia
Isn't mivec original don hav turbo?
In my knowledge the mivec doesn't combine wif turbo,rite??
Rons
29
sg
mivec and turbo is diff..
mivec is NA(natural aspirated)
turbo is turbo aspirated..
and it doesnt combine together in stock..
bvalve
2,330
16
群&#39340
1.6-2.0cc upgrade is for those old days only bro,now u try n ask for it see what answer u get.
bvalve
2,330
16
群&#39340
verticalimit said:
1.6- 2.0 is legal just need the owner himself go register thats. runner go direct fail.
my friend just register a wira VR4 from 1.6 engine..
where does yur friend do the inspection?what procedure need to do?can share some info,i got couple of friends facing this prob......all also stuck in the middle due to 1.6-2.0 prob.
what is the diameter for Mivec v6 (fto) tb?. .
normal mivec is 60mm. .thanks in advance.:_:
