mivec a 4g93,need advise
roadcrew
415
hi,i'm plnning to mivec my 4g93p,ecu 2468.
u guys out there done this modification b4,pls give ur opinion,and advise.
the pro and cons??
praetorian
236
good mod, if properly done. only thing I didn't like was that the power comes in a bit later than I would like.
natagowai
56
agree with praetorian.
If you go on mivec, the only problem is you only can feel the different after reach 5000rpm. Otherwise, not big different if you compare with 4g93.
I just drive 1 of my friend car yesterday which he using mivec engine on WIRA (AUTO). Pretty nice engine and very smooth.. After 5000rpm, you can really feel the "True power" and smooth...
4g93 got 2 type.. 1 is SOHC (previous perdana engine).. which another 1 is DOHC.. but 4G93 DOHC is quite hard to get now.. most halfcut shop is come with SOHC.. this engine powerful but fuel consumption abit high lohh..
if you like to know more.. pls PM me.. :)
georgett
293
sorry... previous perdana engine is 4G63 single cam.
i got 1 4G93 mivec engine for sell... interested ...pm me..
roadcrew
415
ok,i'm driving a putra so i already hav the dohc 4g93,just want to get some advise like using 1jz timing belt,mivec head complete with wiring and ecu,do i also need the map sensor,injector??
currently using a 60mm throttle body,and a stock93p inlet manifold.exhaust is hotbits 4-1 ,till the muffler.need to upgrade to mivec too??
also read frm somewhere that the mivec ecu is for 1.6 need to b rechip or afc to tune it,can the matspeed J5 do the job as well??
alvin24
3,109
27
5,148
Think this has been discussed only like a MILLION TIMES... try using the search function.
lekalo
754
TTDI
ouch.... uncle alvin, he just wanna refresh so ppl remember that such discussions exist... hehe..!!
Dear All,
Would like to ask, my car AC is giving my symptoms that it won't engage properly. There are 2 scenarios to describe my issues:
1.) When outside is damn hot, the compressor clutch will stop working all of the sudden and blows hot air. It's random and it can be rectified if i turn on and off the A/C system.
2.) At high fan speed, the compressor clutch will stop working at random timing.
So far the things i did to try and fix it:
1.) Replace the freon filters
2.) Replace...
