Originally posted by sum-dum-fuk+Nov 27 2004, 08:56 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (sum-dum-fuk @ Nov 27 2004, 08:56 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-kRiminaLz@Aug 6 2004, 04:08
1 more stupid question....
is there much difference between e2 and e3 turbine...
can somebody tell me pls....
i'm using an e3 with an e2 turbine (get it frm half-cut)...
noticed the lag...
do i need to refurbish the turbine again...
all the EVO 1-2-3 series uses a 7cm2 turbine housing...
only diff is the EVO-3 turbos which has a larger compressor wheel base (exducer)
49178-01450 = EVO-1
49178-01460 = EVO-2
49178-01470 = EVO-3 (big 16G)
As for Subaru's running on TD05H, it is a small 16G, only difference is that it uses a small 6cm2 turbine housing, therefore you don't feel much lag but wud run out of breath in the higher range of RPM. [/b][/quote]
eh melv ,
the small 16G from subaru runs on 6cm housing ? does this apply to all small 16G or its just for subaru 16G turbo ?.
cause from what i know the small 16G also runs on 7cm housing and 14B on 6cm housing , but donno about the subaru's turbo .
guys ,
anyway i`ve just restore the specs info
