Mitsubishi Turbo specifications.
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
t04b and t04e is a frame size...
most ppl measure diameter size from the inducer of the compessor wheel...the tip of the wheel where u can see... ;)
tkk
1,201
is the T04B is old model?
what is the best inducer diameter for using in 1.8cc turbo?
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
tkk..
there's no right / wrong size to use...it all has to calculated and also depends on what u want.. ;)
pathfinder
231
confuse :huh: sdf....i think the new range of garrett gt series all apply ball bearing.right or wrong?
if at the turbo stated A/R.68 ....the 68 number refer to what? if 68,is this consider big turbo? what cfm and estimate bhp. help.
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
not all GT series are Ball Bearing...
GT is a new technology on design of each component in the Garrett series...
tkk
1,201
Originally posted by sum-dum-fuk@Mar 3 2005, 08:42
tkk..
[snapback]784133[/snapback]​
thanks for your info. anywway i got a t04E turbo already.
Act-4
134
[tkk...your t04e is taken from what engine..?
if i take from rx-7 engine,can i use it into 4g63??
another question...what is differt betwen GT and t0XX series..??
Thank you... :D
tkk
1,201
Thank you... :D
[snapback]840105[/snapback]​
is a after market turbo. not from any car.
GT turbo is a ball bearing type. t0xx are normal bushing only
TE27levin
384
some more information i want to know..
sify pls answer..
1. what the different of T04B a/r 60 compressor housing and T04E a/r60 compressor housing? both come with same compressor wheel size.
hp rate same?
2. also the turbine housing. .48 T3 and .48 T4
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
lv..
eclipses run a TD04... why do u wan an inbetween ?
lilvee
421
Originally posted by sum-dum-fuk@Mar 28 2005, 10:59
lv..
[snapback]846294[/snapback]​
I heard its from UKDM Eclipses, not JDM which used TD04. btw, its spool faster (TD04) with great and laster G force (TD05). I can get both for my lil potato engine.
err... i go to GTauto last week, ur dyno is gone? :ph34r:
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
JDM specs use TD05..
US spec uses TD04.. ;)
dyno is next door... :D
tkk
1,201
Originally posted by sum-dum-fuk@Mar 28 2005, 08:33
tkk
GT does not mean all are ball bearing.
[snapback]845805[/snapback]​
got it brother... i still newbie mah for turbo hehehe :D
dolly
726
lilvee, are you refering 2 the 2nd gen dsms? if i'm not mistaken those use td025, faster spool than td04 but weaker top end..
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
doll..
td025 too small la... eterna engine uses 2 x td025... :P
lilvee
421
[snapback]847860[/snapback]​
I got no idea laa .. Mr Dolly and me also a newB in this FI world. jus share2 the info..
what i know... its not TD04/05 series, and its from UK spec Mits Eclipse. this snails is hard to find laa.. but shure not TD025 from eterna as sdf said..
my kancil' l2 temperature rise slowly when switch on the aircond but when turn off the aircond, the temperature decreses slowly, when this problem occur, I have changed new aluminium radiator, new fan,overhaul,flushing,direct power fan,check the wayering and grounding, and hoses but the problem still occur. can someone help and give suggestions?the termostat have been remove,i tried with normal l2 radiator,check the meter,every coolant,added extra fan,changed water pump-all these i have...
