Mitsubishi Airtrek Turbo Engine Mounting
yskyes
18
1,503
Hi,
Anyone know the original part number for Airtrek Turbo Engine Mounting???
Thank you..
stutzedward
3,416
561
I just went to Ah Wah to chg. never really copied down the part nbr. I chg all 4 for 1.4k+++
Raven33
Jan 15, 2013
9
503
Singapore
02886d bolt,eng support rod
02709 bracket,eng rr roll stopper
02883 nut,eng support rod
02886c bolt,eng support rod
21831 bracket,t/m mounting body side
21809b stopper,t/m mounting
21896b nut,t/m mounting
21807b bolt,t/m mounting
21809c stopper,t/m mounting
02701 bracket,eng roll stopper
02886b bolt,eng support rod
02890c nut,eng mounting
02891b bolt,eng mounting
02887 washer,eng mounting
02890 nut,eng mounting
02807 bracket,eng fr mounting
02891w bolt,eng mounting
02888 stud,eng mounting
02890s nut,eng mounting
02887s washer,eng mounting
02891t bolt,eng mounting
02891x bolt,eng mounting
02803 bracket,cylinder block eng fr mounting
03152 pulley,timing belt idler
03148 arm,timing belt tensioner
02891z bolt,eng mounting
02887u washer,eng mounting
02891y bolt,eng mounting
---------- Post added at 10:56 PM ---------- 6 hour anti-bump limit - Previous post was at 10:54 PM ----------
Those description with bracket are the mounting
stutzedward
3,416
561
Not sure about latest pricing. Everything also naik except for our salaries. Sigh. U try to ask Ah Wah on pricing la...
zaifulaika
Dec 24, 2013
32
5
508
Tq bro stutz
Sent from my GT-I9300 using Tapatalk
---------- Post added at 03:45 PM ---------- 6 hour anti-bump limit - Previous post was at 03:44 PM ----------
Going to change it today. Too much vibration already
zaifulaika
Dec 24, 2013
32
5
508
Need help... my battery kong last week. Does that effect the setting onboard? Do I need to reconfigure back the computer setting?
stutzedward
3,416
561
There are 2 kinds of setting. Fuel mappings are flash memory. Which means even if you remove the ecu, you will not loose it. That's what ppl refers to as reflashing or remapping. The other one is running setting. They are collected from your driving behavior and idling. It will be gone if battery removed buy it will relearn back in just a few days.
Performance tuning is remapping aka reflashing. U will not loose it with battery removed.
The real identity of The Stig has been officially revealed thanks to an autobiography by the man behind the visor himself. British race driver Ben Collins has revealed details on his role as The Stig for the past seven years in his upcoming book.
The BBC went to great lengths to block the publication of his autobiography, even seeking a court injunction to stop the publication. But the High Court of London...
