Mitsubishi Airtrek Parts
DeaconFrost
284
159
1,543
Idle Control Valve (ICV):
Note: Although ICV meant for other Mitsubishi models can fit, note the difference (Mitsubishi Airtrek ICV on right).
Engine Bearing:
Note: Although bearing meant for other Mitsubishi models (example: VR4) can fit, note the difference (Mitsubishi Airtrek engine bearing on right - bulged centre). See the effects of fitting wrong bearing in 3rd post.
Engine Mountings:
MR961324 Bracket, engine roll stopper
MR961325 Bracket, T/M mounting body side
MR395086 Bracket, RR
MR510407 Rubber, gearbox
MR403504 Bushing, steering
Relay:
MR301978 Relay
Power Window Switch:
MR502232 Switch assembly, FR door power window driver side
Mass Air Flow Sensor:
Aircon Compressor:
DeaconFrost
284
159
1,543
Bro, are you sharing just part numbers? If you intend to sell it, please put it under the Mitsubishi Airtrek Marketplace
Sharing pics.
Mitsubishi Airtrek bearing. Note the bulged centre.
VR4 bearing fitted into Mitsubishi Airtrek.
Effects of fitting wrong bearing into Mitsubishi Airtrek:
Gearbox Oil Seals:
MD174940:
MD707575:
stutzedward
3,416
561
never use VR4 bearing on Airtrek. It's different. I had exactly the same issue. The bearing rail guard cut thru the belt.
When will the bigger cc hybrid cars available in our local Msian market?
Do you think the bigger cc versions will be just as reliable as the current small cc ones?
Will it be costly and pricey?
Can anyone with news or info kindly reply.....:confused::love:
