Loss of power when turning on A/C
sreeman
150
Hi all,
Im using a satria which i added an electronic dashboard ( the air cond controler ).
When ever i on my A/C my car power actually fall's. It is really noticeable loss in power. Was wondering is there anyway for me to prevent the loss in power while on-ing the A/C.
Thanks ~
D-IV
262
Turbocharge the engine. Honestly, you'll always lose power when turning on the A/C. But that also indicates your A/C bearing is not as smooth as it came out first time from the factory. But regardless, it'll always rob power.
sreeman
150
Hmmm, if im not mistaken i think my A/C compressor has something wrong with it, should be the bearing as its making some loud noise these days. Plan to repair it soon. Thanks anyway guys for all your help :D
ART///SPEED
287
Hi all,
Thanks ~
satria 1.3 ?
Jun 28, 2008
4
I guess you are running an EFI engine. There must be a wire that you miss to connect properly between air cond switch from the electronic dashboard and ECU. Everytime you turn on air cond the ECU will activate a valve(forgot what the name is) to allow the engine rev higher to compensate the lost power whenever the compressor is running.
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
if running efi, ecu will compensate the extra load with increase in engine rpm... same goes to power steering pump and aircond compressor pump...
as for carburetor, u'll have fast-idle speed device to control the engine rpm when aircond is switched on...
even all the above, aircond compressor will somehow rob away some of ur engine power because it needs to turn the aircond compressor... powerloss is more noticeable in smaller displacement engine such as 1.3 compare to 1.5...
what u can do is... use smaller aircond compressor so the load wont be so great... the disadvantage is u'll have a less efficient/cooling aircond...
sreeman
150
Oh ok. Thanks alot guys for the info.
Really appreiciate it.
sreeman
150
Duit tak ada la bro, plus i rather get more experience driving first rather than changing to turbo...just got my first car few months back :D
Anyway does anyone know how much would it cost Roughly to change my air cond bearing? I went to an accessory shop in b`fields, who i know the owner and he says 300+ excluding a/c gas, but when i went to a mechanic, he said he can do it for about 100-200. Really confused ><
infusio
44
N.sembilan
1.3 normal lost of power ,to much of drag in the engine try using pivot voltage stabilizer,its ok for my 1.3.n good for campros"sss
try it........
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
try it........
didnnt know voltage stabilizer can remove physical drag from engine...
AD_EG
6,000 RPM
6,328
231
Ipoh
this is news to me also
A Post Every 5 Mins
hi guys, i got a stupid question...
i really wanna know briefly what is the purpose to install Vafc or Safc?
is it up HP or ????
hope master here can let me learn more about this.
thanks a lot!!!
