Local accord sda(cm4/5/6)=accord cl7/9 etc
mrs88
43
1,508
Hi..everyone.wanna ask are the suspension of locally assembly accord sda same to accord cl7/9?beside is the engine mtg the same type?
Low arm
Abs
Upper arm
Spring
Driveshaft
Engine mtg
O2 sensor
Stab bushes
Etc.
mrs88
43
1,508
Hey.beside d shock abs,others like d low arm, bushes,ball joint,upper arm n the rest rear lower n upper arm r they same with local assembly accord(SDA) model?
Anyone been replace the above stuffs? Are the coil springs also share apart of the SDA? The front part steering linkage such as tie rod end/rack end /abs link also tend tend to wear out.tq.
Twin Or Single turbo..
hey...need some advice here la...now im using a v6twinturbo..and i notice is lag of power im planing to change a bigger turbo such as td04 twinblade moded to a ballbearing (can be done right..?) will it turbolag on that..??
