knuckle rvr(evo) 5lug to 4lug
1218
Dec 19, 2010
18
i want to ask any sifu here aboute the knuckle rvr
izzit same among knuckle rvr and evo1.2.3?or event 4g91?
now my problem is like this. i brought the half cut rvr and installed in wira body, but the knuckle was 5 lug.pic as below
1.how i wana convert it to 4 lug wira use pcd100 ?
2.by using the spacer 5 to 4 lug.and many ppl say dun hv in the market. if tempah thy say can not tahan.can break .
3.the drive shaft between rvr and evo or event from 4g91 is same?
thx 4 ur view ans ans
---------- Post added at 01:19 PM ---------- 6 hour anti-bump limit - Previous post was at 01:04 PM ----------
anyone can help me?or jz change he knuckle to evo3?then the disc and cliper use bc
Sup zth, how you fellas been... ill try to post up some of the DIY's that I was able to take some photos...
This is installation is on an RB but it would apply to I would say most cars with a few changes here and there...esp at the wiring or sensor adapters installation. So if you're installing other makes, this guide can still be used. If at any point you are not sure of something just ask away. For this ill be doing Oil temp, Water Temp and Oil Press.
In this kit. What we will need...
