Kembara FC
titan_m
73
1,508
hi guys, my kembara is eating more fuel this time around. It's very strange.
I've gone 300km on a full tank but now, my tank is almost empty and it's only 150km.
have any ideas??
I recently change my spark plugs and used iridium spark plugs and change the spark plug cable to high performance 9.8mm cable.
and also installed a volt stabilizer.
I thought it can save fuel more.
allance
337
8
have any ideas??
bro, ur car is auto or manual?
have u do some modification? like change exhaust or change hi flow air filter?:confused:
r u use big rim or large tyers?
ur engine still gd condition or not?
titan_m
73
1,508
it's automatic.
I didn't change the extractor so it's still stock.
erm, currently using basic 15 inch rims and tires only.
my engine is in good condition I suppose, have to change the mounting though because it shakes a lot.
EvolutionZ
5,000 RPM
5,027
1,448
if yr kembara is the previous batch without the Dvvt...then the FC is terribly high coz its lack of power and full time 4wd......
titan_m
73
1,508
it's the one before DVVT, yeah I understand that its underpowerd and full-time 4WD, but even with that I lost 30km after I change the spark plug and everything.
so I'm wondering why only.
allance
337
8
mybe u using wrong grade off sprak plug! too cooler plug u use i think!
try change new air filter, gear oil n use grade no5 plug
titan_m
73
1,508
I'm currently using the new DENSO Iridium Spark Plugs. No.20 something like that lar, supposed to be more powerful than No.16, not sure how to explain.
yeah, I think gear oil also I have to check. Air filter? think I should change sports air filter?
allance, what you mean too cooler spark plug??
lonelylilpig
832
33
friend u shouldn't use IK20 !!!!!!! U shud use back the 2 side electrode 1 !! Because it is knows for its type of air swirling in the engine n need a 2 head plug to complete its burning !!! Try ask for NGK 1. The denso IK20 only fit for DVVT engines !! If possible us lower viscosity rating engine oil like 10w/40
titan_m
73
1,508
really ar? iridium spark plugs will spoil the car?? aiyo..
IK20 can fit in my engine wor.
allance
337
8
i have try DENSO iridium plug b4, the power lose than b4 compare with stock plug!
the cooler plug is just 4 high compression n turbo engine use! normally NA engine use no5 cooler plug , if denso is IK16=no5 (IK20=no6 cooler) try use NGK plantinum BRK5 is better than DENSO plug, my friend have try denso plug for wish ...he say is fxxking plug , his car got high FC than b4.
dont change high flow air filter u will lose big power at low mid torque, n FC olso get hi, if u dont belive u try get out ur air filter n try drive, u will feel ur pickup no power! so use stock air filter is better!
call or sms me if u want more infor , get my fon no on ur PM:biggrin:
titan_m
73
1,508
so I should use IK16 if Denso?? my friend sell denso so I can get better price from him. change back to 16? I hope I can sell him my spark plug back haha:) it's still brand new. less than a month old.
allance
337
8
try use NGK R plantinum BRK5 more cheaper !
DENSO IK16 n IK20 no more big diffrence olso can use for NA engine, what the bad is plug design not gd
lonelylilpig
832
33
ur plug u can keep it since it won't spoil n have to expiring date. For best result u MUST get back the 2 headed NGK plug. When i'm back at home this fri i try to post the no of the plug ....
To all ZTH member
please give comment of this product... (e.g. good or not etc)
ever tried it before?
Thanks...:wavey::confused:
