K3-VET YRV engine check light code
endy7527
Feb 26, 2011
14
Hi alls, my vet got his check light on since lastweek. So i send to shop to diagnose. These code coming out;
P0171 - System too lean A/F lean malfunction
P1513 - Boost Pressure Malfunction
Hd anyone else ever got this problems? How la to solve it?
DJgErM
4,014
118
3,163
SIC Turn 7 & 8
www.germ.cjb.net
1) AF lean can be caused by multiple items :
-o2 sensor
-injector
-ecu problem itself
2) boost pressure malfunction
-check ur internal wastegate/actuator
-whether ur vacuum hose and boost pressure hose are plugged in correctly...
-vacuum and boost sensor (the 3 small square boxes on ur rocker cover...2 black one maroon/red)
endy7527
14
Is this the boost pressure sensor?
See the T join is for boost meter..Can i juz spray some wd40 inside..maybe some stuff stuck inside..huuu...
endy7527
14
1 thing also i wud like to ask... Whenever i boosting, when it reach 0.7-0.8 bar, the boost will like retard n unstable, the rev also like 'semput' for a while until it reach 0.9 bar.. On 0.9 everthing went smooth as usual.. Why its like dat aa? Could it be the sensor problems? Or the actuator..this problem occur since i had this engine.. Is it normal or not yea?
DJgErM
4,014
118
3,163
SIC Turn 7 & 8
www.germ.cjb.net
cant determine the rev unstable definition...but usually boosting will have minor spikes...like unstable...but maybe check ur internal actuator...usually it should be minor...maybe we can meet up someday..and u can illustrate the problem..
endy7527
14
Update! Today i decided 2 ask my fren 2 test my sensor on his car, seems my sensor working good.. Last try, Reset all- disconnect -ve terminal of the batery, switch on the headlamp for 30nd n connect it back.. Start up the engine, YESS PROBLEMO SOLVED!! no more check engine light.. Hehe.. Now only the boost pressure problem left.. Thanks all...
I am going to get a new car soon. I narrowed down to Teana and Camry. I am worried especially about the after sales service problems etc. I am avoiding Mazda 6 because of some friends complaints regarding Bermaz tardiness etc. I also do not like the Honda Accord.
I think these cars suck when doing corners after driving my mother's BMW 320 but I can't afford a BMW now.
I need a reliable car for work mainly to go to Singapore a lot.
Which would be a better buy? Nissan Teana 2.5 and...
