Japan engine converted continental car
zac
1,347
231
Johor Bahru
Hi guys,
I really love the look and ride quality of BMW e39 and also performance engine like 2jz, been searching for one until I was told my mech friend that better don't try this kind of vehicle... He was saying although the engine can be fitted perfectly, but the car itself will lost all safety features like abs or airbag, is that true? Although I don't speed much, but safety features are important too.
Or is it possible that a converted conti car like BMW e39, e60,e65,e66 with all features works perfectly?
Second question, there are some altezza fitted with 1jz in zth marketplace, are those cars safety features like I mentioned above abs and airbag still working perfectly since 1jz belongs to Toyota family too?
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
if u convert a japan engine into a conti car, dont think those features : airbag, ebd, cruise control etc.. works.
unless u dun mind spending a bomb for wiring those features.
zac
1,347
231
Johor Bahru
Thanks for the clear cut answer, then I will not consider them anymore lol, hv to increase budget for ori performance conti like m5 or rs6...
But, how bout altezza? All features gone too? If translated with 1jz or 2jz?
DanzEterna
15,911
3,371
3,213
PJ
same thing. all features gone. try asking bushidofang bout altezza.
hello all,
i got the GAB SS series adjustables for my vios. so, i will be spending time tweaking it! however, some queries below:
1. my front spring rate is 6kg and my rear is 4kg. with my damping set to hard, the car is bumpy, but in corners, slight body roll is noted. should i up my spring rate to further reduce body roll, or is slight roll acceptable? I have thought of installing anti-roll bar to the rear, but was advised not to do so as it may distort the suspension from doing its...
