inquiry 'bout vtec activation point
epitBDL
232
can use any other method to set the activation point? eg:shift light
fobs
3,752
8
what do u mean "other method"???
what shift light are u talking abt, bro???
1. u can use vafc
2. use chipped ecu
hattech-v
Over 10,000 RPM!
12,756
12
Seri Kembangan
www.avantech.com.my
vtec controller like spoon vc3e, vafc, emanage.
u cannot use shift light to activate ur vtec point..
or u can use manual activation by using switch which is directly send current to the vtec solenoid... hehe..
J101
1,304
malaysia
u might want to re-consider the idea of changing the vtec activation point. the point were meant for the maps designed in the ecu. by simply moving it earlier or later with incorrent fueling and ignition may create power loss.
shiroitenshi
3,677
170
Agree with J101.
If you engage too early, the car will jerk a bit during switchover, as not enough volume passing true for the vtec duration.
if you engage it too late, then you will see a flat spot in torque.
Some of the VTEC controllers use knobs.
Me, I'm on hondata now, so no need for such things.
mzsu
124
Agree with J101.
you meant, it's better to use factory setting for vtec activation point....:confused:
bien335
1,834
48
1,648
Johor Bahru
exactomundo
if set earlier, the VTEC cant sustain all the way to redline, unless u have a set of cams
if too early, like shiro-san said, u'll get a dip in torque, unless ur running a chipped ECU
wah, u got Hondata? Fawrking sweet man.
shiroitenshi
3,677
170
Yeah.. got hondata messed with it for the past two months already..
my engine is surprisingly resistant to knocking even when I'm running high advance numbers.. (O_o)
As for vtec point, better I show than say. I set it suprisingly close to stock, at 5400 rpm.
I'll have to dig up my old datalogs. I'll post it sometime tommorow.
one has the example of a flat spot, and the other of putting vtec too early.
bien335
1,834
48
1,648
Johor Bahru
my engine is surprisingly resistant to knocking.. (O_o)
one has the example of a flat spot.
knocking??
what engine u got bro?? H22a?? wuwuwuw
erm, ur running Hondata right, what base map?
yeah, post ur datalogs, share share ma
darkemperor
318
shiro...
how much u got it? is it s300 or the pro...new or used...can plug n play to any ecu rite...? what about the software...dont mind so many q...kekeke...
n is it true by engaging the vtec early u wont get the power (hp&torque) at most compression required by the engine???
bien...
u also wan hondata kaaa....then we both can sit together ler with the h22....shiro is on b16..
epitBDL
232
wow!! so much tech helps there. thanx everyone replied.
epitBDL
232
wow,thx for the tech reply.very useful 4 newbie like me.
evoX2
1,167
KCH
shiro already achived Ph.D in hondata already (Permanent Head Damage) :P
shiroitenshi
3,677
170
Lol..
Anyway.. for those wondering... the thread is updated, and it should be listed in the first page right now.. datalogs are there too.
Oh, and I can't seem to find the older logs of my tests with early vtec points.
bien335
1,834
48
1,648
Johor Bahru
shiro...
bien...
erm, if enuf funds, maybe. my car now no value, heck, i paid more to get the swap and engine compared to the value of my SM4 now.
oohhh, B16, lansi
ey darkemperor, where in u Johor u at?
shiroitenshi
3,677
170
b16 lansi? Wah.. like that one ah?
Anyway, the questions are answered on the hondata thread.
J101
1,304
malaysia
you can get your hondata from the malaysia authorised dealer
JC Racing- Tuners & Accessories
you can get more details on hondata from their website regarding compatibility with your engine.
Hondata - Honda ECU Modification and Enhancement
shiro...
bien...
With the ink hardly dry yet on the agreement to by Team Lotus owner Tony Fernandes to buy over niche British sportscar maker Caterham, it made perfect marketing sense to produce a limited edition Lotus-liveried version of the Caterham Seven.
Next, to further hype up the move, you take a Team Lotus Formula One driver, in this case Heikki Kovalainen, and let him loose in the car to kick it sideways and do a...
