Hyundai Elantra 1.8 Enigne Light on
Sep 23, 2009
my car 2001 model, the engine light on recently. What is the actual problem to my car? Send to workshop, foreman check the oxygen sensor and say no problem on it.
Hope you all can help me. Don wan spend $$ change part and the problem didt solve.
basis
24
1,503
Hi Guy
I think is normal they is 2 sensor in the exhaust one is oxygen sensor, one is so called " pollution" sensor at the back of exhaust. I guess your car catalytic converter is time up.
Same like my, i change to aftermarket exhaust, this light had been on forever. 3 year to be exact, just kuat makan minyak..... and check your catalytic converter, make sure it don't clog your exhaust volume output.
Chai333
oo... recently feel my car like no power as last time. Feel that my car consume petrol high a bit. Today make an appointment to services center, hope can find out the problem and solve it. Feel not comfortable when c the engine light on... haha
basis
24
1,503
Yup, go and check from the services center , i know my one, the error point to the extractor i change cant detect 4 pipes instead only one pipe exhaust.That may be the reason for the my high fuel consumption issue. ;) But i will to endure it the power increase is quick alot.
The Marketplace Top Posts
Its pretty common to see Mat salleh adding 2T as additives in their petrol/diesel tank (can do search from BITOG). They usually use TCW3 rated 2T since it is ashless and will not dirty up the combusion chamber..
when added to petrol/diesel, the 2T basically lubricate and clean up the fuel pump, injector top piston and etc.. This will give a very smooth ride and better fuel consumption... I have tried it myself and found that the car become very smooth but nothing much improve on the FC...
