How to "ketuk" fender
azir
62
anyone know how to knock the fender. my rear fender need to "ketuk" la, my 16" rims sangkut ......
i have an experience ketuk my bro fender...paint crack, how to avoid this aa.... my idea is to ketuk+water on my fender, coz my logic here, water can cause the body@area cold......
gavan
1,408
Shah Alam
bro, i also ketuk my fender and the paint crack also....so i think best is ketuk and ketuk, then later touch up, i dont think there is a way for it not to crack....paint is hard when dried, so, sure crack wan....
reddice
1,013
54
5,148
Tochigi Japan
japan.com
im also using 16inch..on satria..the trick is ketuk until cannot ketuk anymore..seriously..knock it hard..very hard..im using satria GTI original set.and the set is cutted.and the fender inside is being knock..hard..if that cannot solve your problem..use "batang paip"..they put it in the space between the tyres and the fender and push the fender out..unbeliveable?believe it..
azir
62
ketuk very hard ke? surely paint crack, other that u r using GTI fender, sure the ketuk fender can see...
whatdamn
1,344
Cheras, KL, Mal
the steel pipe method is better. even the jap drifters are using that technique cause it gives a more uniform arch than 'ketuk'-ing. can't remember which option video volume had it.
eddie368
156
my wira rear fender always kena tyre... cos rim is wide... how to use paip
n push up using 15 inchgo the gap is quite high
LilKeV84
193
Subang Jaya
hhmm...my fender after accident(prev owner) they din ketuk nicely...if see properly left and right diff shape a bit 1...space between tyre and fender of both sides oso diff 1
using pipe...sounds quite like a good idea...should try it b4 i paint my car :p
sam1741
1,188
hi all...
i confused.. anyone can teach me?
ketuk fender?
u mean knock which part?
is it outside or inside?
make it more outside so it wont touch the tyre?
or make it more high so it wont touch the tyre?
bro n sifu,
i nid ur help to teach me how to remove da front center panel of my dashboard as well as da cd player.. i plan to repaint da center panel of my dashboard which consist of cd player, clock holder, air cond blower.. etc.. teach me how to dismantle or remove it.. thx in advance..
best regards
