It will look nice at night, especially when you used coloured bulb. Is it will blinking if I ON signal if I do like that???DarkAccoon said:whatever would you want to do that for?
it is confusing for other drivers as well
but, if you want it to be always on then just tap the positive from your headlights and connected it to your side signal (fender) lamp
OIC, will try it. thanks.takumi86 said:yes bro will blink as well when signal ON..
so many car on road use this kinda style liao. ;).
u mean connect 1 wire from small headlamp to fender lamp. only 1 wire?WAJA2003 said:i tot is u fende bulb - wire tap to u small headlamp - 1 worrr...
only need add 1 wire only..easy job.
Ya...tat's true. Causing more confuse than safety. Speaking from experience here.DarkAccoon said:side marker lights and signal lights are two different thing
for one, in malaysia, how many cars has these side marker lights
this debate will be similiar to whether a not it is correct to on hazard light when it is raining and thus very subjective
from my point of view,
keeping the signal light on at all times is kinda dangerous
as humans, we normally give a short glance on certain things
many may not realise it, but when we see another car's signal, we normally take a very short glance and our brains will translate the message to us that the car ones to change lane
however, in that short moment, we sometimes fail to see that the signal light is on at all times and not blinking, thus causing our brain to mistranslate these signals
and from wrong judgement, we as driver will take into defence (well, most normal non-aggresive drivers do) and make way for the other car to turn into our lane
