u are totally correct bro......The answer is u only can swap the rear suspension setup only, the front absorber impossible to swap due to FD1 / FD2 lower arm & subframe is totally different with original FD2R.
what if I use the lower arm and the anti-roll bar, can I make it?because i already have the driveshaft, front knuckle+brembo+rotor, front suspension.Hi demonz, have to modify front suspension bracket cause totally diff screw hole.
