My preference, hard front springs with medium compression(if 30+ clicks, means around 15-17, and if got rebound, middle to hard. Depending on preference, and bump steer.
Rear, soft springs, low-mid compression, low to mid rebound, will cause body roll more than standard with low setting, so use the low setting with bigger arb. Afaik, this is quite a common setting for FF hondas,
Ride height, i'd still do the corner weight to get them right, I don't quite agree with the lower rear end though, since if there's no problem, only rear will be lower during acceleration, during parking, should be level.
