There is / was this company located in KL specialising in boosting CR-Zs. I can't remember the exact name but they had a handful of boosted CR-Zs in either turbo or supercharged form, this car may have come from there
Yaya.. that shub be the case.. but im not sure whether thick/metal gasket is using.. the only way is to ask the workshop who modded tis car.. same goes to the bar level..
I will arrange a day n get tis car check by the workshop. :)
---------- Post added at 04:27 PM ---------- 6 hour anti-bump limit - Previous post was at 04:22 PM ----------
Yaya...that shub b the case...but im not sure whether thick/metal gasket is using.. the only way is to ask the workshop who modded tis car..same goes to the boost level..
I will arrange a day n get tis car check by the workshop :)
---------- Post added at 04:44 PM ---------- 6 hour anti-bump limit - Previous post was at 04:27 PM ----------
Sifuss,
May i ask how possible can i know the engine internal is havin problem or not? I mean anyway to check or any symptoms tat i can know off?
Jus did abit of readings on compression testing.. hehe now got abit of understanding.
Mind to ask few question:
1) if after did the wet test, compression is higher than dry test(first round of test without putting oil) means the rings and/or cylinder is worn. No change in the readings means has a bad valve. Then is it means normal condition, the compression reading on wet test mus b lower than dry test??
2)Normally how much they charge for doin compression test???
3)what r the things i shud demand for checking beside the compression test? Currently in my mind is to check
a) adjustable see got leaking or not
b) brake system
c) tyres (but dealer agreed to change 2nd hand for me)
Thank you thank you :)))
Are all 4 cylinders having about the same reading. If yes, then probably okJs brought d car for compression test.. hmm the reading is 200+ psi between 12-16 kpa... how come r?? I remember u all said 100 to 150 psi is it??? All cylinder show same reading..
Then they recommend do the leg down test.. which is to compress air inside n see any leaking o..again all show same result..hmm shud b ok gua..
I ask them do wet test they said now no more ppl do wet test wor :( nooby me so i js oklo.. since all result all consistent shub b ok gua..
Feeling Regreted last time din go n b technician.. now nooby.. :(
If about the same reading means good. If varies too much means some cylinder not good.Yaya..all abt da same..
Hahaha.. bought it to use for daily but sometimes if i got outstation (to east msia) so can't bring da car along lo.. not frequent but if out will b 2wks so i worried n ask u all lo.
Hehe
Got bad experience somemore nooob bo bian nid to ask haha.
VR4 but 2WD as in FWD....Hahahha.. okok no problem..kaki kaki
Wad car u driving btw???
