Honda Crz Turbo
KeeSeong
78
508
Hi all sifus out there,
Currently im considering to buy a crz.. but this car previously was a demo car (according to the salesman) not sure wad demo is it hehe.. so tis car already comes with turbocharged and supercharged.. driven less than 10000km and its selling ard 78k (hvt confirm yet).
i quite like tis car as the price is reasonable to me and would like to try turbo car hehe..the dealer also agreed to let me bring tis car check by any car workshop.
My concern is im not sure how much it cost for maintenance it case problems come.. as the car will be used as daily driving car.. and is it true that problems will b lesser if u dun tekan heavily.. but wad if outstation?? can the turbo tahan altho i drive normal? i worried coz heard a lot ppl complaining on turbo car... haizzz
i reli need advise from sifus sifus..every advise r reli appreciated..
Don't remember any CRZ variants having a turbo. If it has a turbo means already modified. CRZ basically is a hybrid running NA petrol and electric.
KeeSeong
78
508
Yaya... tia car already modified by previous owner for demo purpose.. then he sold off to car dealer lo...
KeeSeong
78
508
Not very sure leh.. i din ask abt that. normally they give 1 or 2 weeks warranty rite? How long warranty shud i get from them o??
---------- Post added at 12:58 PM ---------- 6 hour anti-bump limit - Previous post was at 12:39 PM ----------
I worried the reliability of hybrid + TC...
Hybrid, if previous owner did not do anything, should be ok. Only worried what he did to turbo/super charge the engine. BOT what boost, did he lower the compression, change to turbo parts etc. etc.
BOT without changing to forged parts you may have reliability issues later especially running higher boost. You need to check all this....:rolleyes:
KeeSeong
78
508
Ooo.. okok.. i will ask the mods from the previous owner..
The dealer give me 2 to 3 weeks warranty..
Js now tested the car.. feel ok in terms of the transmission n the engine.. not sure how much the car boosting so i js press not too heavy lo.
Js the problem on d brake.. got sound when braking not sure is it brake pad finished.
And the adjustable suspension... v bumpy haha mayb too long nvr use adjustable abit not used to it.
Jac83
164
54
I'll advice u do a bit of reading and study on how an originally NA is turbocharged. Besides u need to know how to maintain a turbo charged car even more so since this is a BOT instead of originally turbo engine. Go read some on how to maintain a BOT especially on the oil change, temperature reading, boost level and etc before jumping into buying it. Otherwise you will only burn more money for repairs when u encounter issues or problems of which can be prevented should u know of it earlier before it happened.
15,390
I'm surprised no one is talking about the twin charge. He said it's both super and turbo charged.
If that really is the case, the car is very heavily modified and will probably need engine management (standalone). If you're an enthusiast and know your way around cars, it's probably an interesting car to buy. But if you're a newbie, it'll be a nightmare of a car to look after since you don't know what was done to the car to have this sort of modification.
Oh! I miss that. I thought TS not sure turbo or super, read too fast.....hhahahhahahha
Supra_Fanatics
20,685
3,998
This one need to get ST1l opinion. Had experienced in Turbocharged CRZ before.
KeeSeong
78
508
I further noted tis car went up to magazine b4 and i read the modifications i think shud b only TC la... not SC inside.. to further ask the workshop later.. and its bolt on without modified the internal.. hyvrid is still runnning.. clutch remain original.. js changed the stock injector, hondata ecu.
The engine was running smoothly. Tested the car was ok leh.. boosting level not sure.. i think less than 1.0 bar..
I wonder when i bring the car for checking, how they check wherher the internal is still running normally? I don think they will open the head n check??
But thanks for all the comments..hehe
If BOT they should have added thick head gasket to reduce the compression. Then boost should be low since internal not changed. Boost like 0.4 to 0.5. Higher boost can but internals won't last. Better check properly
Tom
TIMETOATTACK
Jul 6, 2000
5,566
3,229
There is / was this company located in KL specialising in boosting CR-Zs. I can't remember the exact name but they had a handful of boosted CR-Zs in either turbo or supercharged form, this car may have come from there
KeeSeong
78
508
Yaya.. that shub be the case.. but im not sure whether thick/metal gasket is using.. the only way is to ask the workshop who modded tis car.. same goes to the bar level..
I will arrange a day n get tis car check by the workshop. :)
---------- Post added at 04:27 PM ---------- 6 hour anti-bump limit - Previous post was at 04:22 PM ----------
Yaya...that shub b the case...but im not sure whether thick/metal gasket is using.. the only way is to ask the workshop who modded tis car..same goes to the boost level..
I will arrange a day n get tis car check by the workshop :)
---------- Post added at 04:44 PM ---------- 6 hour anti-bump limit - Previous post was at 04:27 PM ----------
Sifuss,
May i ask how possible can i know the engine internal is havin problem or not? I mean anyway to check or any symptoms tat i can know off?
7,514
Sifuss,
easiest and simplest way is to do compression test on all 4 cylinder... dry test as well as wet test....
KeeSeong
78
508
Jus did abit of readings on compression testing.. hehe now got abit of understanding.
Mind to ask few question:
1) if after did the wet test, compression is higher than dry test(first round of test without putting oil) means the rings and/or cylinder is worn. No change in the readings means has a bad valve. Then is it means normal condition, the compression reading on wet test mus b lower than dry test??
2)Normally how much they charge for doin compression test???
3)what r the things i shud demand for checking beside the compression test? Currently in my mind is to check
a) adjustable see got leaking or not
b) brake system
c) tyres (but dealer agreed to change 2nd hand for me)
Thank you thank you :)))
7,514
b) brake system
4 cyl dry test: all must be pretty close reading (or dead even consistent reading) *GOOD*
4 cyl wet test...usually old good engine reading be slightly higher than dry test but still maintain consistency *GOOD*
dry reading much lower than wet reading = bad ring
no change in wet/dry reading probably bad valve seat
if got variation, need to check with manufacturer (honda workshop manual)
not sure how much workshop charges....probably from rm70-300 depends
is it possible to remove the CV joint from the drive shaft without taking the whole shaft out from the transmission?
the last time i did this DIY, I took the whole shaft out. now, i have to change the gaiter (CV boot/cover) again, i wonder if the CV joint can be removed while maintaining the shaft in the transmission. it'd make the work easier and there wont be any loss of transmission fluid.
anybody knows the answer? is it possible?
