help on dc5r offset
Stylites-x
1,139
anyone knoes wuts the best offset rim for dc5r aka integra ? and to prevent hitting my brembo calliper ..
the original 17" was +60 ..
newbie here ! :smokin:
thx in advance !
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
what do you mean by best offset?
as long as your next wheel offset is similar if not, a little more negative, the wheel spoke and overall clearance from the inside of the wheel can clear the calipers, there shouldn't be a problem.
if there's slight clearance issue, or if you're looking for a perfect offset, then some spacers would help.
Stylites-x
1,139
means my nex rims shud be a lil negative to my current +60 offset ?
or as long as theres a space to clear the calipers, shud be fine n the offset doesnt matters.
actually i dont c any rims set of +60 for my point of view .. n asked around the tyres shop around my area for the perfect offset figure n no one knew bout it.
n a lil concern bout safety than the good lookin rims around.
KhonBaRot1
21
1,503
just my own thinking : a rim is a rim, u got the right size, pcd and hole count, its ready to go.
still, for safety, use coned spacer instead of the normal one. another thing, try out different spacer thickness, to make sure the rubber wont scrape on the inside ( the absorbers for instance) and the outside( the body ).
to a lot of guys that i know, clearance on the inside is the most important. if the rubber will still scrape the chassis after the best possible adjustments with the spacers, a tyre jack would do the trick to create more space between the rubber and the mudguard, instead of "knocking the mudguard".
honestly, not many of us ever discussed offset during fitting in new rims...:rolleyes:
Stylites-x
1,139
thx to tom n barot for those useful advice ..
really appreciate it :biggrin:
Car Stolen @ Taman Connaught, Cheras, KL.
Proton Satria GTI (PEV 5442).
Colour: Silver with 'PARANOID' sticker at the back of the car.
Come back from work at 2400 but at 0600 hours already gone!
If found please contact +6016-4815530 or any police stations immediately.
URGENT! Thanks!
Award will be given if found in good condition
