help.. my vacuum meter no reading
sam1741
1,188
hi all....
i got this vacuum meter i not yet install...
just now i go pull out a tube (connected to the intake hose)
and connect to my vacuum...
no reading one.. (at engine idle)
what happened? i got engine problem?
later i connect the vacuum meter to a tube
and use my mouth to suck..
the meter do move...
btw.. the vacuum meter reading written inch /hg
so is it normal one?
sam1741
1,188
no la.. i think correct
if put finger cover the hose
can slightly feel the vacuum inside....
so what is the normal reading when idleing?
Darth
368
Selangor
17-22 inch/hg for proper 'healthy' engine
tykoh
351
Ipoh
tykoh88.blogspot.com
i think you are connecting to the wrong hose lah.... u should make
a T-joint at the hose from engine to throttle body... dont connect the
hose of engine to air filter box...
just some experience... :)
darkbob
152
Johor Bahry
may i ask u what engine u r using ? what car ?
maybe u tapped the wrong hose ?
jaywat
1,329
If u r connecting the correct hose but no reading, means ur car got vacuum problem and cannot start already la. Make sure it's the correct hose first. what car?
sam1741
1,188
hi all...
my car is datsun 120y...
the place i connect.. is the 'box' right after the carburetor and before my air filter..
dono if is correct or not?
PCV cannot connect.. as mine is just a big pipe and lead to the ground.. ( the mech that transplant this datsun engine dun conenct PCV.. cause hose size not right, then i cant find any place also)
so.. is the place correct? or should i find other place?
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
i think u connected it to the wrong vac. line. use or T vac. line that are source from intake manifold or after carb.
darkbob
152
Johor Bahry
sam,
hmm.. in this case...
try looking behind ur carburetor, is there a Vacuum Distributor... it looks something like a connecter which connects lots of VAcuum Hoses... TRy tapping it from there.. :D
Good Luck Trying....
Dear all 0-100 Otai2 & forumer friends,
I just bought an Apexi EL2 Boost meter from someone that claim it as ORIGINAL gauge. After some closely spot, I doubt about the authenticity of this meter. Bad finishing, low grade plastic, non quality fitting & etc. Here I attached some picture for all of 0-100 members make some verification on this APEXi EL2 Boost meter. :bawling:
I really2 appreciated if someone can help me spot the authenticity of this gauge...
