help me pls pls pls!!!!!
93na
597
20
hai every wan i need help!!!!! i m drivin a 4g93 engine that was bot before but now i m running na!!! so the ecu was rechip to suit the bot since now it na the fuel and performance is so bad!!!! i when to a few workshop all of them say the only way is use emanage coming up to 2k!!!!! wat can i do if i dont wan to used emanage!!! can i just swap and fit a normal 4g93 ecu in!!!!! i dont know where and wat type of rechip was done!!!!! but using 97 ecu system!!!
pls pls i need help going broke pumping fuel!!!!!!! ha ha ha!!!!
thanks every wan!!!:listen::listen::wavey:
fatbusterd
315
4
klang n brunei
no stok ecu??..erm..put back stok chip??...tune back ur engine??..
go d place whr u did d mods la...find stok ecu..ke??
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
U could try going to MLOC Forum, there I guess more of MLOC owners will be able to assist u my fren.
93na
597
20
ya bro thinkng bot it!!! but by mid next year i wan to fix highcams on my ride so i m thinking should i just install emanage!!!!
btw do have a stock ecu????????????
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
u rechip it so it can read positive boost pressure... but it is still not fine tuned... it is advisible to get emanage to fine tune it...
speed2horizon
2,798
334
1,683
What he was trying to say was, he demoded his engine and got the Force induction kit removed. So, A/F no more compatible.
