HELP: How to remove Clarion HU
EG656
21
Need to know how to remove my Clarion HU (single disc with detachable face) from my car. I want to replace it with another set. Is there a special tool required? Managed only to remove the plastic trim surround but cannot pull out the HU.
cacin
1,000
5
5,138
Penang
what car are you using?
Normally there's a latch on the left and right side of your HU. U need to insert a metal piece at both side before you can take out the HU.
EG656
21
It's an E36 BMW. What size of metal piece to insert? I know how to remove a Pioneer HU with the metal piece provided but cant seem to find a slot on the left/right sides of the Clarion HU. Any suggestions?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
use some kinda metal hook not bigger than the width of ur headunit... slide it in between the side of ur HU... try pull it out... if cant, use blade to slice off the top part of ur HU.. coz they might use 2way gam to hold ur HU in place...
edwin_lcw
1,242
Setapak
eg 656 u wanna sell your head unit ar ?
erm actually very easy larr ..... pull out the HU then detach the wires then okay oledi
the frame i dunno larr
hahahahahahahahahahaha
EG656
21
not selling la - transfer to another car. Cant seem to take it out. Want to DIY.
cacin
1,000
5
5,138
Penang
do you see any hole if you remove the faceplate?
Maybe you can remove the HU from there.
At the edge of each corner (when the faceplate is removed), there would be a hole where you can insert a (4 actually) pins to pull the HU out. The normal way that I know is once you inserted the pins, pull it outwards (all 4) before pulling the HU out.
Hope this helps.
HPC and MAM's first ever 4 Endurance race in Sepang will commence this June 12th 2011. This will be a private event sanctioned by the Motorsports Association of Malaysia (MAM) and allows for all race prepared cars old and new ranging from 1600cc, 1800cc and 2000cc.
If you you have yourself a Honda Civic EG for example, your...
