Help: Civic 92-95 Power Window Motor replacement
shiroitenshi
3,676
170
Hi, I'm new to the Zero-2-Hundred community, and I'm driving a 92-95 civic and hails from Kelantan.
I wonder if anyone can help me with the problem I'm having. I've tried the forum search function, and I couldn't find any threads relating to this problem, maybe I'm using the wrong search terms, and for that I apologize if this is a duplicate thread.
The power window mechanism is a scissors type linkage, and the motor died just recently, and I'm planning to replace it. However, the window is stuck fully closed, and I can't access the bolts to remove the windows, so I can't remove the linkage to replace the motor either. I think there's a manual way to lower the windows so that I can access the mounting bolts, but I can't seem to find it, and the workshop manual I have doesn't help either.
I'm 100 percent sure that it's not a problem with the window's track rails, or the linkage seizing up.
I know that workshops can solve this for me.. but as a DIY person.. I wish to accomplish it myself.
Anyone knows how to manually wind down the windows so I can access the mounting bolts?
Even a general idea will help.. if you have another car using similar linkage for power windows.. maybe you can suggest something.
Thanks in advance for any help offered.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
- remove door panel...
- remove some bolts holding the window...
- remove the whole window out of the door panel...
- remove some screws that holds the bracket...
- remove the whole bracket out from the door panel...
- change the motor...
- fix back everything the reverse way when u take everything out...
this is the steps to change proton power window motor la... i think its almost the same with ur car.... jz remember main thing, remove any bolts that gets in the way and take off the whole bracket only can change the motor...
more pictoral guide, go to my thread: http://www.zerotohundred.com/newforums/showthread.php?t=76607&page=8
or can visit khguan diy sifo website:
http://khguan.fotopic.net/c921830.html
shiroitenshi
3,676
170
Thanks for the suggestions, and the steps are right and I already removed the door panel, but the problem I'm having is that I can't access the bolts holding the windows to remove the windows. I can only access it when it's down, and the window open. But currently it's stuck on close, and I can only access one bolt out of two.
I'm thinking I'm missing something. There must be a way to remove just the motor (or the gear operating the scissor link) so I can manually wind down the windows and access those bolts holding the windows.
BTW if I'm not wrong, I think proton uses a cable system instead of a sturdy scissor linkage.
Thanks again for the suggestions, anyway.. I was thinking I'd get absolute zero on responses.
The car door is still sitting bare as I ponder the removal of the plastic cover (it's definitely a one use item, so I've to go search for a new one tommorow). I hope I can resolve it by tommorow after removal of the plastic cover. Things might become clearer then.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
nope... proton also uses scissors link... but much weaker version... thats why they snapped or breakdown often... haha...
steps should be correct lar... jz try to get the bolts out.... it should be somewhere inside behind the door panel....
good luck...
shiroitenshi
3,676
170
Okay.. will try later today.. feel so sleepy right now... ZZZZz..
Thanks for the suggestions dude.. I'll see if it works out..
shiroitenshi
3,676
170
I guess the power window will be put on hold for a while. Just sent it off for B16A transplant, the fella just called today and went to have a look at the halfcut. All good, so confirmed the purchase and transplant.
I'll probably do a writeup in case anyone else wants to DIY their power windows once it's back in my hands.
Last week went to one shopping complex, during the time to leaving, noticed one wira aeroback next to my car..
Engine still running.. no one inside n doors was locked.. engine was start to smoke out.. noticed that was turbo timer on the stering cover, time still running 8++ minutes left..
Wah.. donno wat for the owner set the turbo timer for a long time, believe it was only standard car..
Then wat i can do, just report it the security guard nearby and leaving, before it blown my car...
