GSR TURBO problem help me
putra888
24
GSR TURBO problem help me and how tu up boast with ma problem
hello bro may be u all can help me plz ya if u can do so...
so im driving GSR turbo engine,, all in standard specifikasi...
so what happen my wiring turbo gsr has wiring problem so the ecu GSR burn n bust(meletop)
so check the wiring cannot settle with the problem...
so what i did ,,i use back mine putra wiring n bought E-manage to settle ma problem... so settle all the problem
NOW what i wanna to know ,, can i use GSR turbo ECU with putra1.8 wiring,,,
and now my standard boast is 0.75,,,
what should i do to make to 1.1 bar..
just to let know mine engine with matel gasket,,with e manage
that all ,, other is standard,,
do need to buy fuel pump,safc2. or anthing else
plz help anyone there
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
try to make it 1.0 bar enuf for standard spec
u need extractor,downpipe, open port filter (suggested), n 3" piping from front to end....use better motor oil (Q8 suggested) n boost controller....boost meter as well.....
oh ya....sports absorber n spring n good tyre..so handling better.....n strut bar
DjRevo`
311
Ipoh Mali
bro i never heard anyone use gsr ecu on putra wiring... i dono whether u can do that or not... and u said u already got e-manage why do u need safc for ? both also piggy back bro... if u wanna boost ur car just make sure enough fuel
2slow2steady
671
p.j
dj revo is right....got e manage no need afc already.
1.0 bar internal can take,only the fuel problem.
i doubt the car will jerk when high rev if running without fuel regulator or bigger fuel pump when boost 1 bar.
zero_kool
464
yo dude.....u pm me but u din reply..haha...anyway...yeah..dj revo is right....u oledi hv e-manage..so y u want the safc? both are piggy backing. as i said before, u may wanna boost ur car but on the long run....u'll regret it....but if u insist....like many hv replied...u'll hv to do alot of things for ur gsr before u can get up to 1.0 boost. extractor, wastegate, probably injectors, fuel pump, probably a td-05/06 turbo, bigger i/c...about ur wiring....i am not sure about whether u can use putra wiring on gsr la....but the best is get back to the original gsr wirings la.....tat's my suggestion.
hear from u dude..:)
Beijing Auto International Corporation or BAIC has officially launched the D20, a 5-door hatchback with styling said to be derived from the original Mercedes-Benz B-Class. To be locally-assembled either in Gurun or Pekan, it is a joint venture between BAIC (pronounced as baik) and local partner Amber Dual.
BAIC D20
