can anyone recommend any good ones for the above items??? thanks in advance
My one also the same, I install Arospeed grounding cable and Reizin stablizer, after 1 week i check, the light still dim a while when the aircond kick in then after that all go back to normal. I check my battery power still full power (sampai green color - max level )Originally posted by ondgennis@Sep 29 2004, 15:41
is up to u to spend ur money lah...but my one after install n do grouding point..the light still will dim a while lo...
then the voltmeter also show the reading not stable...but better a bit than last time didnt install lah...
:rolleyes: i think ur t/body or ur fan switch sensor dirty oledi lah...Originally posted by MetalMic@Nov 15 2004, 05:23
Greetings all...me new here,
Not sure whether grounding will cause that to happen. All stock cars came with grounding as well but not that good one ler.
But normally static shock will only happen at night especially if its raining coz the air temp is much lower.
I have grounding & the Raizin thingy,don experience light dim yet when air con kicks in but FC is like still the same only.
Only improvement is idling with aircon on is much more softer now.
I have a digital voltmeter and i notice after the lights,aircon bla bla is on the volt will drop to somewhere 13.6 then after a while it will stabillize to 14v.
I have non related question to all the sifus here, at normal idling my tacho reads about 1000rpm bt when the air con is turned on it jumped to around 1250rpm then down to 1150rpm, wat is going ar?? :huh:
I tot normally after aircon kicks in the rpm should be lower?
Originally posted by flamefox850@Nov 13 2004, 12:15
that's why u all get 'zapped' becos ur car is now +ve in charge..ur car want electron from ur body after it's electron being sucked in the +ve terminal of battery[snapback]500968[/snapback]
Similar threads | |
