Greetings all...me new here,
Not sure whether grounding will cause that to happen. All stock cars came with grounding as well but not that good one ler.
But normally static shock will only happen at night especially if its raining coz the air temp is much lower.
I have grounding & the Raizin thingy,don experience light dim yet when air con kicks in but FC is like still the same only.
Only improvement is idling with aircon on is much more softer now.
I have a digital voltmeter and i notice after the lights,aircon bla bla is on the volt will drop to somewhere 13.6 then after a while it will stabillize to 14v.
I have non related question to all the sifus here, at normal idling my tacho reads about 1000rpm bt when the air con is turned on it jumped to around 1250rpm then down to 1150rpm, wat is going ar?? :huh:
I tot normally after aircon kicks in the rpm should be lower?
