techtic 500 RPM Senior Member Joined Jun 21, 2004 Messages 624 Points 3,016 Location Pienieng Sep 10, 2004 #1 Can we change the standard gearbox ratio?? mine ratio i think too low. so how to channge the ratio one ... cannot understand la.
M moppy Known Member Senior Member Joined Feb 9, 2004 Messages 273 Points 3,016 Sep 10, 2004 #2 U need to find which gear manufacturer made the aftermarket gear...
techtic 500 RPM Senior Member Joined Jun 21, 2004 Messages 624 Points 3,016 Location Pienieng Sep 10, 2004 #3 Originally posted by moppy@Sep 10 2004, 11:07 AM U need to find which gear manufacturer made the aftermarket gear... Click to expand... im using a 2.0 diesel gearbox. dunno how many ratio ... but i know it using a low ratio. can i change just the ratio only?? without changing the whole gearbox?
M moppy Known Member Senior Member Joined Feb 9, 2004 Messages 273 Points 3,016 Sep 10, 2004 #4 As long as the gear can exchangable from others gb is fit... i think should be ok.. gua...
V vteckiller Supporting Merchants Senior Member Joined Nov 17, 2003 Messages 1,606 Points 3,148 Sep 13, 2004 #5 yes u can if honda is very easy can just buy aftermarket gearings and final drive.. if mitsubishi a bit harder..need to match with a few gear box, can be done but not everyone can do. :) joshua
R rorytate 4,000 RPM Senior Member Joined Nov 17, 2003 Messages 4,417 Points 3,138 Sep 15, 2004 #6 Joshua is rite, i've tried changing the 5th gear ratio to lower ones... thus taking the old mistubishi super touring one. Just the 5th gear..running 100km/h with 2700rpm.... damn syok..and fuel saving...other gear are stocks.. Took out the housing..ting tang ting tang..did the whole thing...last last the bearing doesnt fit. End up me fixing the gearbox not the mech. dang~!
