4G15 Gearbox n Ratio
devraj
135
Malaysia
Hi Sifu Sifu out there....
need an advise on this... i'm using 4g15 engine with original gearbox from 4g13.
I found that when im running on 110km/h the RPM is hitting to 4.5 - 5..
is there anything i can do? can i use any other gearbox to reduce the ratio?
advise what i can do? what wil b the positive n negative if i change the g/box
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
change ur final gear ratio... but that will be costly...
there is a reason for such high rpm... 4g15 isnt a powerful engine... it needs close gear ratio to extract the best power out of ur engine...
devraj
135
Malaysia
so what i can do about my gearbox lah? i dont wanna change engine again lah... money matters..... what i can wit wat m having now?
cipan_supercas
1,698
7
Shah Alam
www.draxecu.com
Proton 1.3 and 1.5 have exactly the same gear ratios. I suspect that you have slipped your clutch or your tachometer and speedometer are not reporting correctly.
MiOKu
136
i think so also...
devraj
135
Malaysia
Then what is the reading supposed to be in my speedometer of tachometer?
putra4767
550
i have a wira 4g15p... i feel it's very good oledy bro compared to 4g13...which is
kinda sluggish i feel for a wira...Iswara is ok coz it's lighter
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
iswara with 4g15 is ok....
but final drive rpm is kinda high... not good if u are using noisy muffler or if u wanna save fuel in long distance drive....
devraj
135
Malaysia
4g13p ya correct u can get 3.5-4rpm when u hitting 110-120....
but im talking about 4g15p with 4g13p gearbox.....
4g13p and 4g15p is same gearbox for 100%?? or is there any slight diffrences? if yes pls let know.....by technically or in mechanically
so sifu sifu all telling ...that its on right condition is it? so i supposed not to worry about the ratio isit?
ky_fei
1,007
Kay Elle
change to 1.6 or 1.8 final drive , 4.2 sumthing
then u can cruise highway without worries, but if u plan to drive normally, stick to the same final drive ratio. =) coz converting final drive ratio gonna cost , not a bomb, but at least, it burn holes in ur wallet
The Marketplace Top Posts
Currently the double signal button malfunction after I open it up. I tried to put it back, but it doesn't work after that. Please show some proper instruction to fix it please ><"
