No Other Belts Help Protect Your Engine Investment While Delivering High Performance Like Gates Racing Performance Timing Belts.
Gates Racing Performance Timing Belts are incredibly strong and extremely heat resistant. Constructed of HNBR elastomeric composites, Gates Racing Performance Timing Belts are as much as 300% stronger than stock belts and deliver up to three times the heat resistance. You can count on them to hold up to the rigors of high horsepower, which is extremely important with interference engines.
-Belts are precision ground, not cut, so they fit the pulley with absolute perfection
-Superior construction provides up to three times the heat resistance
-Gripping teeth reinforced with aramid and nylon rubber minimise wear
-As much as 300% stronger than the standard aftermarket belt
-Withstand the rigors of high horsepower
-Durable nylon fiber provides extra wear resistance, doubling tooth strength
-Patented EPDM compound gives Gates Racing belts extended service life
TEL: 012-9154001
TEL: 012-9154001
