funny prob opinion needed urgently
traize
519
5
hi all sifu,
i need some help a very funny thing happened to my car, usually if drive long period, distance or very fast the water tempreature will drop to 30 -50c normal is 90c is is ok or not? my car is 4g54 2.6L petrol
p/s i know tht water tempreature goes up is bad but if go down is it ok? any effect on my car? any sifu or mech familiar with this prob?:hmmmm:
Bump: added info my water temp sensor n meter (both on meter cluster and on 56mm gauge) all are working fine as i have tested them just in case tht they are not working properly :banghead::banghead:
loose_end
3,649
197
Malaysia
Erm , non-sifu here..Erm , the meter got problem ?..
traize
519
5
bro read the last piece meter is ok even i tot this the prob so install external defi meter with sensor also same prob
PocketRocket
'(00) Mod'er
11,164
953
3,213
Up Yours
ur water pump need replacing?
ur temp. sensor kong liao
1st time i see pajero put defi... :O
come to think of it, my car also like this...when i drive up genting no prob
but when i go down, my temp needle goes down to zero...
maybe i'm dropping gear too much
traize
519
5
sensor new, water pump also new coz just replace it last raya, the prob dnt show on down hill only, even go uphill also like tht but not drop to 0 just to 30c or 50c only ( normal working temp 90c) and tht defi my fren give he change car n the new owner dont want the meter set so he give me all for free la
jeffayn
621
62
3,028
Klang
do you experience any heavy fuel consumption problem after found out the drop ?
traize
519
5
no still normal 20cent per km, tht wht puzzeled me
jeffayn
621
62
3,028
Klang
in that case i dun think should be any big problem ... hahaha...some car tends to run at lower temperature especially when running at highway because the air flow into the compartment is roughly about 10-15 times more than in a city driving
if cant sense any big changes in driving is perfectly ok.
some car when running at low temp, it will cause fuel efficiency to drop 15-20% especially in a diesel car, because they need to work at it optimum temperature.
but if yours fc is ok, then no prob la...
one more place you can check is the thermostate, it can be jam and open all the way hahaa...
traize
519
5
thanks bro, my car is petrol, will check the thermostat
azameel
152
yup
if thermostat blocked or removed
ur temp will drop kaw2 one
until you thought ur meter is faulty
kena once
Does anyone know or have insider info on whether Honda Malaysia is bringing in the new Civic Type R? No doubt it's the euro version Civic but HM might consider making an exception for high performance models?
