Gear problem
May 28, 2017
Seremban
Hello, please I need your help. I am using Nissan cefiro A33, recently I observed that when driving the gear is running smoothly but when I applied break there is drawback like a force with sound when the gear is returning back. But during pick up time the gear is smooth. Please advice me on what to do. Thanks
jerrysiow
407
146
1,543
Seremban
Have you change your ATF fluid recently?
Check your auto-gear oil level and top up if it's not enough and use the correct ATF fluid recommended by Nissan.
A sudden jerk when it decelerates sounds like the gears in the GB are struggling to move. Either you're using the wrong oil, or it's over/under filled or your GB will need a overhaul soon since the Cefiro is a pretty old car.
hi all sifu and member,
i have vios 2011 model that is with ori exhausr stock, now i plan to modified the exhaust with low noise and pickup and end energier more better for fc, so what is agak agak price and ok lah the material piping as my budjet not more that rm800, plan change ori stock i think is 4-2-1 one
