what kind of fuel pump and injector suitable for my upgrade?i wanna put 272 cam and retain the stock turbo.
thanks
thanks
which website?Originally posted by dolly@Mar 8 2005, 13:50
actually walbro 255lph if purchased online is <rm400 shipping included. the shops in sunway rapes you on the price :(
4g63 evo4Originally posted by antonio@Mar 8 2005, 12:14
what engine...
if just cams then no necassary to change injector unless ur boosting quite high....but then again b4 boosting metal head gasket n "so-on" mods have been done or not...if just cams no need change but if u wan to -+200 % of ur standard injector upgrade if ok....lets say from 510 no need to go for 1000 if ur not above 2bar...but can use oso 1000 its just u have to get a management to control it...if not...rugi minyak...or engine running rich kaw kaw....
fuel pump is adequate if the fuel pressure don drop too low...if drop very low then change to those "power" or "walbro" or Sard brands...those merc bosch oso can...but cannot fit lar...need mods not just PnP...
boost too high = engine blow +turbo blow(sumtimes)Originally posted by pathfinder@Mar 8 2005, 16:03
dolly.
if put 272 cams,so can pull easily too 7500rpm.but with standard TD05-16G,i think it cannot go high boost.which one come 1st when flooring the throttle...boost limit or rev limit?
