fto v6 mivec
mines998
1,048
149
663
Copy from RPW website
Finally we are finishing this masterpiece. ombining the 6A12 DOHC Mivec 2.0 engine with the 2.5 Litre 6A13 Turbo Engine. The result - a 12.5 : 1 2.5 DOHC Mivec engine. Torque, rev's and a FTO Owners dream
Racing Performance Works -
6A12/6A12 Mivec Hybrid Engine
The plan - turn a normal every day FTO into something everyone fears - especially your wallet!!
Tech Specs
Mitsubishi 6A13 DOHC Mivec Hybrid Engine utilising 6A12 DOHC Mivec heads onto a 6A13 DOHC Turbo Engine block
RPW / CP Custom 12.5 : 1 Forged pistons suitable for NOS
Forged Steel 6A13 Conrods
Engine bored, honed and acid cleaned
RPW Ported and Polished Cylinder heads
RPW Valve springs and Vernier Camshaft Gears
RPW Stage 1 Improved Camshafts on high rpm lobes, custom 1/2 Grind improvement on low rpm lobes
Doesn't look like a lot but this 4 year project is nearing completion. Soon some lucky FTO owner will be fitting this into his vehicle, and have the ultimate combination of looks, torque, power, rpm. A 2.5 Litre 8500 rpm screamer - everything a FTO owner would dream about.
This engine has had the custom pistons and rods manafactured for this specific setup. Not really a hell of a lot more to say at this moment - other than enjoy the photos below. This engine is expected to be finished by the end of September 2006 and then into a FTO vehicle. Other external mods would more than likely be
RPW Modified 3-1 Extractors, custom long tube "Race Design" to accomodate longer engine block
RPW Modified customed aluminium billet flywheel with heavy duty cushioned multi paddle clutch
Haltech E11 ECU to control everything
RPW Modified intake manifold with larger 65mm throttle body
Larger 240cc Injectors to replace the stock 6A12 165cc Injectors
Before anyone asks - this engine is actually a combination of 3 engines - 6A12 DOHC Mivec, 6A13 SOHC, 6A13 DOHC Turbo engine. Yes we can build more of these but do not expect change out of $10,000 by the time we source all the components, custom make pistons, rods etc and don't even talk about the timing belt and tensioner setup. 1 year of hard work on that alone. But we are sure if you are keen, the results will show it.
Veloc
3,234
991
Sabah
Can fit? Are the bores of the mivec head and 6A13 same?
mines998
1,048
149
663
Base in RPW project it can be fit but how many work need to be done that is not sure. Maybe can try to get the engine manual to study. Infact 6A12TT itself can ram to 8k rpm. Due to Malaysia most ppl play 6A12TT so we have less infomation regarding FTO mod.
Hi all,
Can i know how to modify clutch cable to adjust the heigh ?
ok, there is one rubber, and 1 yellow color screw rite ?
we shift clockwise mean it'll tighten and move inside.
What is the right way to adjust ???
Justnow i loosen the rubber, then pull the cable, then i shift anticlockwise to the screw so it'll go outside ....
then i press my clucth the gear cant shift liow !!!!!
then i do do do, the clutch too low till i move 0.01cm the car can engine die off
hope...
