Flywheel That Could Fit Campro CFE Crankshaft??
Jan 22, 2015
Singapore
Hi! I am planning to replace my Campro engine crankshaft with the CFE crankshaft. Any idea where I could find a flywheel that could fit the CFE crank since its 6 bolts rather than 5 bolts?
Thanks!
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if not mistaken cfe crank is a tiny bit shorter stroke than normal campro...and i think they changed the design a little bit and perhaps better tooling tolerance as well...
i think for 6bolt flywheel maybe can try check from other mitsubishi gen2 engine (engine terbalik type)....or even maybe can try compare with 4g1x series flywheel first....
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
LittleWhiteWagon
1,656
187
P.J
Thanks!
Perhaps you can try getting a CJ4A mivec flywheel? From what I remember those are 6 bolt. Johor should have some lying around in chopshops.
How come you decided to choose a CFE crank over a waja crank? Just curious haha.
peterj
1,321
258
1,683
Kuching
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
forged but 2 mm shorter in stroke... if conrod and piston stay stock... it will become low com set up like those who use thick head gasket
---------- Post added at 04:32 PM ---------- 6 hour anti-bump limit - Previous post was at 04:29 PM ----------
PROTON CAMPRO 1.6 CFE ENGINE - KERETA DOT INFO
read it:driver:
Yes. Thats why we ask why in the previous posts bro.
Here's some extra jalapeno sauce to sprinkle on yesterdays static shots of the Scion FR-S Concept, basically Scion's take on the Toyota-Subaru jointly-developed rear-wheel drive coupe. Toyota have now been so kind as to release two videos of the FR-S, a really short one and a really long one, to further stroke our loins and tease us silly whilst...
