All WiSE owner, or those who changed their extractor to the WiSE 4-2-1 know that the engine bay is extra hotter than normal Wira.
This is due to the nature of the 4-2-1 extractor, and also due to the heatshield that is not long enough to cover the top of the primary pipes.
Other than hot engine bay, that leads to accelerated ageing of the rubber & plastic parts, hotter intake air temperature, etc... the exposed extractor also means that the heat lost in the tubing can be affected by the cooling effect of the radiator fan.
To certain extend the cooling effect might cause a drop in the temperature in the exhaust stream. Air of lower temperature has higher static pressure. If this happenes in the exhaust stream, a higher back pressure can be expected.
Some experts recommend termal wrapping to reduce the cooling effect.
Me and guan initially had this idea long time ago to make an extension of the stock heatshild to cover the primary pipes. Just yesterday we found ourselves free for some DIYs..
These are the photos for sharing: http://drexchan.fotopic.net/c976627.html
You may ask about the details of the DIY in here..
materials:
1. manila card
2. thin aluminum sheet
3. AA1100 aluminum panels (1-mm thick)
tools & stationaries:
1. marker pen
2. a pair of scissors for paper
3. a pair of metal cutter
4. cutter
5. ruler
6. cordless drill and 3.5mm drill bid
7. jigsaw
8. rivette tool, 5 pcs of rivettes
9. flat and round files
cost: unknown
duration:: 2 hours
difficulty: 50:50
materials:
1. manila card
1. marker pen
4. cutter
5. ruler
7. jigsaw
cost: unknown
duration:: 2 hours
difficulty: 50:50
