Engine conversion w124
Jun 26, 2016
I currently have a Mercedes w124 e220. It's inactive due to so many problems collected along the years. I'm trying to find a good workshop to do engine conversion. Planning to fit a 1jz in it as I heard it's powerful and easier to maintain compared to rb25. Will have to consideregister changing the brakes too. Suspension has been changed, currently using bilstein absorbers and eibach springs.
So i'm looking for a good workshop that converts engines and does a beautiful job. Need advise.
Give Lim a shout at Primus Auto Car Service Centre. They're in 13, Jalan Kuchai Maju 6, Kuchai Entrepreneurs Park, 58200 Kuala Lumpur
0123975118
He does 1JZs in BMWs, I don't think a Merc would be a problem.
C99D-MMC5537
287
78
Just want to share with u 1 important info regarding transplaning w124 engine with 1/2jz @ rb20/25 engine.
If u choose Rb engine, u need to use the RB rear axle too to ensure the overall ratio is ngam with the engine power. This will involve a lot modification which require a very skillful mechanic to do it. Overall Merc gear ratio number are higher (than nissan) therefore the final drive (rearaxle) using a smaller ratio number (like 3.2 @ 3.4) to compesate the gearbox high ratio number.
But if u choose 1/2JZ engine, u still can using the Merc rear axle since the toyota gearbox high ratio number quite match with the Merc rear axle.
Rb gearbox × merc axle = a very low overall ratio which will make the 1st gear feels almost like 3rd gear. Dont believe to some moron out there who always think a lower ratio mean lower rpm = fuel saving. To low overall ratio will make your RB running in boost even while cruising at 120kmh on highway.
RB gearbox × RB axle = perfect.
JZ gearbox × merc axle = ngam
P/s: overall ratio = gear ratio × final ratio. (This "overall ratio" is my own term and may be wrong since i not sure the correct term :biggrin::biggrin::biggrin:)
kayour
326
41
how about dealing with puspakom/jpj
easy or...so so??
Dudes and dudettes,
My regular mech has somehow adjusted my tappet. There's this funny sound when I accelerate the car at certain gears and certain rpms. Sounds a little harsh. Will try to record the sound. He then one day checked something else in my car, and suddenly, he said, "wah, your tappet very noisy la". I told him that he was the one who adjusted it and he said if adjust back, have to pay money again. I told him that it was only 1-2 months since he adjusted it and he just said...
