drill stock brake disc can/gud or not?
m3 power
924
7
can stock brake disc be drill to make braking more efficiency?:burnout: my car dun have aftermarket drill brake disc.:banghead: so can drill stock 1 or not? dangerous or not?:driver: where shop can do it?:listen: appreciate taikor2 opinion.:adore:
GT_AUTO
3,503
71
K.Trg
www.facebook.com
seen a few crack disc after the drilling.some of them last for years.
i don't know whether to encourage u to do it or not.but if u still
insist on doing it,try check out those X-drill disc first for reference.
u will notice that the upper part of the surface is bigger then the
lower part of the disc.the hole is narrow.meaning is that if u drill
the surface,let say 5mm,the lower part should be around 3-2mm.
like V shape.that will make ur disc much stronger the directly drill
it 5mm from top to bottom.just my 2 cent.
edwin_lcw
1,242
Setapak
got good n no good one la ..... i depends on ppl n how they drive .... i ok no porblem but i was very aware of the disc is not that strong anymore .... it varies with your driving style .... ppl always jam their brakes then not advisable ...
mag9556
2,770
43
Not recommended... dun ever try it as once drill at the correct parts.. ok for you, but once wrongly drill will have no difference somemore more worst bro...
like PonG said.. try it at Speedworks they might have it...
CarroTT
177
not recommended lar
Its much better if u make grooves instead, but its harder to do, needs specialized machine to cut the grooves
m3 power
924
7
pong
axt got ya? :listen:
thanx all bro for the oppinion. i oso scared it will effect the disc. thats y nid sifu opinion. ormally aftermarket 1 how much? just change the disc only rite? same diameter or a bit bigger the disc? tq :adore:
mag9556
2,770
43
It is better that you go to the shop and double check it for your own good...
We just can recommend and advice onli.. at the end the buying power is at you hand... Good Luck M3...
renxun
1,138
37
high possibility will crack if the machinist drill in too fast....and disc weight balancing will offset....
CarroTT
177
ngeeheheehheee, at last spotted renxun here :burnout:
Nieto
494
might be risk if u drill it... jus like gamble
m3 power
924
7
saw it oredi. their got it. but dun know the price is for 1 piece or set of 2. i'll go check it. install it easy only rite?
mag9556
2,770
43
If the disc is made to suit ori size.. just plug and play onli lor..
ericwong
hi..
may i noe if for my honda car nomally can use this type of brake disc..
thx..
The first leg of the Shell FuelSave Challenge saw police officer Tan Moh Chuan crowned as the Johor state winner, netting him RM3,000 worth of prizes and a ticket to the grand finals that will be held in October this year. He will go up against the winners of the Selangor and Penang legs for the RM50,000 grand prize.
Tan managed the feat by clocking in 29.45km on a single liter of Shell FuelSave 95 along...
