DIY install relay
sam1741
1,188
hi everyone
anyone know how?
i heard after install relay the lamp will get brighter..
what value for the relay should i use?
(i dono how many volt i should use. from my experience, if use volt value too high, then maybe the electric wont able to 'switch on' the relay, if use too low voltage value, then will damage it)
anyone got wiring guide to install relay to headlamp?
(is it original electric to headlamp wire to relay, to switch it on/off, then when the relay is turn on, the headlamp get electric directly from battery? )
hope anyone can help
thanks
Boink Boink
191
Hello Just curious. Are you refering to additional spot/fog lamps or your existing car headlights..?? :blink:
IronJ
294
if install for spot/fog light, how?!...
if install for headlight, how?...
interested to know both... hehehe...
g88
3,081
54
5,148
Well i guessed you are refering to this type of relay. PPl install additional relay + wiring to their headlight mainly becoz the upgrade the stock standard 55/60w bulb to 90/100w bulb.
If you using high wattage bulb w/o upgrading the wiring possibility you might melt your existing stock headlight connector.
Hope this help :)
sam1741
1,188
ya... is the thing like in the pic above...
can buy those thing at electronic shop?
how much?
easy to DIY?
Vyraz
119
penang
how much?
easy to DIY?
sammy... car spare part shop got liao..
u can find it near gama..
its one of the lorongs. there is also a famous bike spare part shop there too..
they're side by side to each other.
sam1741
1,188
hi vyraz bro
go inside from side of gama...
after that turn left/right?
sam1741
1,188
hi.. the diagram is clear....
but where to connect to alternator.. i not clear
anyone can provide pic please?
thanks
starwing
422
thanks
you can tap to ur + battery terminal
