DIY Fix Common EvoX Idling Problem
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
This applied to EvoX and It might be applicable to other Evos with the same symptom...
Symptom : Rough Idling after spirited drive, Boosts or when is engine hot...
What to do? : Check the Fuel Pressure Regulator Vacuum Hose
I searched in Google on this symptoms and was surprised to find more than 20 EvoX owners having this issue...
Here is the zoomed out view. It is located under the engine cover... So just remove the plastic cover for a better view.
A simple fix will be just to cable tie it...
however, I take an additional step to ensure it will not happen again.
I realised the hose was hardened, probably due to the heat, so... I am replacing it with Silicon Hose.
Just cable tie it back to the original positions, and it's DONE!
Definitely fixed my Idling problem... and I think.. will get better mileage on my full tank too... we will see!
Share to all your EvoX, Ralliart, 4B11T friends... !
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
You mean that vacuum hose just pops out after a hard drive or high boost?
Wah
Yeah.. Kinda silly right?
I think the 2011 EvoX onwards fixed this problem.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Seen the same problem in 4 x 4B11T already...
all fixed with either cable ties or change hose.
Good Job guys!
pengyu
189
129
yeap..happened to me as well before..
cable tied it.
The Marketplace Top Posts
i just curious...this is my 2cent idea....
if u notice that in the market...small strobe light...usually people connect it to the brake light...then it goes blink2...
wut im trying to do is, connect it to the small light infront....then put a switch....open it la...not with the blue casing la.......
so, put it facing the light chrome....then it will reflect better....
any cfu's can give me comment about my 2cent ideas?
then we no need to buy the expensive one...but surely the expensive...
