DIY Fix Common EvoX Idling Problem
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
This applied to EvoX and It might be applicable to other Evos with the same symptom...
Symptom : Rough Idling after spirited drive, Boosts or when is engine hot...
What to do? : Check the Fuel Pressure Regulator Vacuum Hose
I searched in Google on this symptoms and was surprised to find more than 20 EvoX owners having this issue...
Here is the zoomed out view. It is located under the engine cover... So just remove the plastic cover for a better view.
A simple fix will be just to cable tie it...
however, I take an additional step to ensure it will not happen again.
I realised the hose was hardened, probably due to the heat, so... I am replacing it with Silicon Hose.
Just cable tie it back to the original positions, and it's DONE!
Definitely fixed my Idling problem... and I think.. will get better mileage on my full tank too... we will see!
Share to all your EvoX, Ralliart, 4B11T friends... !
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
You mean that vacuum hose just pops out after a hard drive or high boost?
Wah
Yeah.. Kinda silly right?
I think the 2011 EvoX onwards fixed this problem.
johnsonlam
DIY King
1,182
313
3,183
Balik Pulau, KL
Seen the same problem in 4 x 4B11T already...
all fixed with either cable ties or change hose.
Good Job guys!
pengyu
189
129
yeap..happened to me as well before..
cable tied it.
What is TiTAN custom build performance shock absorber?
TiTAN's are proudly 100% Malaysian designed and built custom build performance shock absorber. Designed as the ultimate custom build shock absorber set for Malaysian roads and drivers! TiTAN's been around for 5 years.
TiTAN is an inverted monotube design, ala WRC/Rally cars style for maximum strength AND durablity for Malaysian roads.
What is a monotube?
a monotube is a single tube where all the damper oil...
