DIY - Dismantle TB
nicholas1007
510
anyone can tell me satria 1.3 year 2000. after dismantle TB, cleaning then install bak. need to reset ECU??
ppl told me mine is Mitsubishi. wat mitsubishi they meant?? the ECU??
thx.
can anyone tell me??
coz i wan to understand i need or need not before DIY.
jswong
209
9
Maybe no need to reset ECU.. for Siemens-VDO, the idling will be high for a few minutes but the ECU will compensate automatically.
Removing the TB carefully won't result in torn gasket, can easily remove, clean, and put back. The TB is aluminum alloy and doesn't rust, so it's actually quite easy to clean will all sorts of solvents. Heck, I've even tried spraying diluted dishwasher and Dynamo at it. Dynamo works damn well!! You can see the black gunk just flowing right off! Then you can just hose the TB clean, wipe it, shake it to rid it of all that water and leave it under the hot sun for a while to ensure it's totally dried.
I've cleaned mine many many times by using water and dishwasher or Dynamo.. no TB damage or problems so far :wavey:
xtorm
1,590
49
been awhile since i posted here.....:D
since you guys edi dismantle the throttle, take a stick or something like it and attach a sponge at the end, dig the sponge to some solvent and clean the intake manifold as well, your engine will love it, change those gasket (if it old) and put some high temp gum on it too, did mine and love it
So the Super GT race series just came and went as fast as it was out on the track, but it hasn't left without searing images of perspiration, tight clothes (or the lack thereof) and wonderful smiles that made an already hot race even hotter...
