Diy - Digital Volt Meter
hitz
1,111
5
5,138
Kepong, KL
Hi there, any sifu got any digram to do the Digital Volt Meter?
donCityZ
2,230
33
1,648
I also thinking of doing it.
I have 2 things in mind...
1. LM3914 IC... this ic is very famous at jalan pasar. (LED gauge type)
2. Buy simple digital multimeter and mod it. (digital number type)
still contemplating which is easiest and cost worthy.
hitz
1,111
5
5,138
Kepong, KL
My bro in law is using the jalan pasar LM3914 IC type. Not showing the accurate voltage. So i prefer to mod the digital multimeter if possible. But digital multimeter to big to mount it on the deskboard... That why thinking to diy a simple and small digital volt meter. But can't find the diagram.
donCityZ
2,230
33
1,648
If u know how to program PIC,
it can be done.. but i think too much hassle.
me, going for mini digitalmeter i think..
since more accurate.. try to find a smallest one.
donCityZ
2,230
33
1,648
find a caplang one le.. those china branded cheap2..
hitz
1,111
5
5,138
Kepong, KL
Those china brand cheap cheap also more than RM50 above wor... Hehehehehe... Still trying to find it also...
donCityZ
2,230
33
1,648
Do post up if find it.. and i post up too if i find it...
at least <rm20 is reasonable right?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
i got my digital multimeter for rm25.... but not gauge that can be mounted on dashboard la... its still enough for me lor... once in a while open hood and check the voltage.... see see still got batt or not...
donCityZ
2,230
33
1,648
skywalker, i think u are missing the point.
we are talking about modifying a multimeter to put on the
dashboard (to spice up our car interior looks)..
khguan
4,818
26
Seri Kembangan
fotopic.net
eh no pics eh... it is just a 3 digit LED display thing enclosed is a small plastic casing... just stick on ur dashboard area n connect the wires to the power source.. n there u get ur voltage reading...
the size is approx. 4cm x 2cm x 2cm..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
i know larr.... but if u think installing voltmeter jz to spice up the car interior, its wrong lor.... gauges are to give u information mah.... but nowadays, many tend to use them as decorative purposes....
no offence though, i do view them cool... jz dont have the cash to go with the looks...:regular_smile:
jz my 2 cents...
hitz
1,111
5
5,138
Kepong, KL
Bro which acc. shop you bought it? I've try to find it but all dun've wor... All more then rm100++ wan... Mind to share where u buy it?
Hi guys,
my engine needs to be over hauled and since i'm going to, I was thinking of increasing the c.c to 2.4. The usual way is to stroke up. Buy a 4G64, use the block and crank, change the pistons. However, to use a 4G64 block, I'll have to send for JPJ approval right? Any problems there? A friend of mine who drives an E3 says that it's not nessesary to change block, in fact it's better to just use the crank and get custom forged pistons that are shorter. Is it really possible to do that &...
