Cutting Spring & Tyre Setup
Wira Y2K
10
Im blur already on which to choose either cut my stock 1.6 spring about 1" or leave it stock.
If i cut it it'll be pure for look only but i dont want my car to bounce at corner's,dangerous woooo.
For the moment i think i'll leave it stock.Cos if i cut it i cant revert back.
hey guys,
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
