Cutting Spring & Tyre Setup
Wira Y2K
10
Im using Wira 1.6 and changed the front & rear abs to gas shocks.My tyre setup is 195/60/15 for front & 195/65/15 for the rear.
My question is...
1.Will using different tyre size effect my handling?
2.The shop wants to cut my standard front spring about 1-2 inch to make it look lower,is this advisable?
3.What are my other option to make my front end lower?
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
1. weight not distributed to your tyres evenly
2. cut spring.. you wont like to attack corner...
3. err..whats your purpose to make your front lower? if emergency brake your front brake have to work harder and will take more time for ur car to full stop...danger...
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
My question is...
differences in tire section height should be ok. but both left n right hv to be the same. NOT OK if differences in tire section width.
not advisable...wan lower? change sports spring.
lower? either adjustable shock or lowered sport spring will do.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
1) not vr noticeable... still ok... but better go with the same profile tyres all around...
2) NO.... dont ever cut ur springs.... it will totally mess up ur spring rebound rate....
3) fit sport springs at the front... but still, not advisable to go 'rear tonggek'.... vr dangerous especially when u do hard braking...
MiOKu
136
1) i think bigger rim size will benefit u in handling but dun put too big ...15" for wira i think is juz nice...
2) dun ever potong ur springs... u will regret...u wont dare to take corners and even speeding at highway...ur car will jump like kangaroo... get a sport spring better...
3) get a pair of lowered front spring or adjustable...but dun toggek behind too high...seriously is dangerous while braking....
Wira Y2K
10
Thanks all for the reply...
1.So i guess it ok then,waiting to change all tyre to 60 series.
2.Ok so i wont cut the spring,thanks.
3.Adjustable are too hard,how much lower will my car be with sport spring?Currently about 4 Finger front.Im afraid if change to sport spring my 60 series tyre will bang the body when car is bouncing.
simon
292
MiOKu said:
1)
i hv cut one round of my standard spring for my wira in front......its still comfortable & never jump like kangaroo in the highway also...in fact it was jumping like kangaroo when i was using sports springs earlier :)
MiOKu
136
lol.. wont de if 15" rim... mine last time use performax spring with ori abs front bout 2 and a half finger like tat with 195/55/r15... use longer will get lower a bit...
MiOKu
136
u try cutting all 4... it juz felt hard...no rebounds....
Wira Y2K
10
So if cut my front springs 1" its acceptable?My car wont go crazy?
nitrus
2,895
35
1,648
juz go get APM performax springs or something la ... dun cut ur springs la
so nice ady ur setup, u somemore asked about handling .. u cut ur springs later dunno apa jadi .. dun do it man.
simon
292
im using cut springs (only one round) for the front & let me tell you its far more better than using those apm performax spring which tends to bounce & feel uncomfortable on uneven roads. you will not feel any bounciness at all & it is comfortable on uneven roads as well & the handling is fine. but the cut spring must be compressed well & fitted into the shock abs properly.
nitrus
2,895
35
1,648
simon : your feeling towards the cut springs may be different for Wira Y2k..
anyway,
Wira Y2k , whichever way u use, do update us with the outcome ya?
cheers.
Hi guys,
I am new to car mod. Need some expert advice on this.
I am seeking for the extra top end power of my car. I am driving a 1.8MT and it tops out at 205km/h (need a bit more to pit against most modern cars). Coincidentally my father drives a 2.0AT Inspira and I am thinking of engine swap between the two cars since he does not really utilise its full power.
I do not wish to go down the BOT way due to the potential risk of destroying the engine and the issue of long-term reliability...
