Change my topic from DCS to ALCS (alternator load cutting system)
I want to change my DIY from to DCS to ALCS (alternator load cutting system). Don't hurry to modify. I would like to explain it clearly then now can't show you all but it's look no difficant to DIY but the result of this project is guarantee. I just explain it as follow. The engine have many load to drive, such as motor fan, air compressor and generator. Because many loads, engine will lost power for driving equipment. Thus, we reduce the load of engine the power of engine become better. That my project will concern to the chargine system. Normaly, the battery will re-charging by generator but the generator will charge every engine work that no need alway charging. The generator will compose rotor and field coil. The rotor will use electrical from battery to make electromagnetic field. The engine will use power to drive the rotor that have magnetic field that cause of lost the power. So, this project will cut the magnetic field at rotor by control the voltage that supply to rotor coil. This is briefly explain. I will take photo this DIY step by step.
