Cleaning engine by Changing EO in less than 100km mileage
leinnz
333
57
3,028
It sounds crazy. I am thinking to clean/flushed the engine of my 100K km mileage myvi by changing the EO again after the second day of changing EO.
Do you think this will work or waste of EO?
What?
meaning Monday - Change EO and filter. Tues - Change EO and filter again?
No point. If you're gonna do that - might as well run it for about 100km before the change. Or flush with Royal Purple oil during your oil change.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
A waste if u have been changing the oil regularly.
Anyway i have been changing semi syn oil at mileage of only 5k km and fully syn at well below 10k km. Thats a waste too as it can still be used.However Tesco is selling oil at cheap price so i really dont mind.
leinnz
333
57
3,028
Service mostly according to mileage and time
What?
Monday Change EO and oil filter, tuesday change EO again. My mileage daily about 100km.
Flushing with Engine Oil Flush. heard alot of bad stories when googled
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
just use higher quality oil in slightly shorter interval than usually recommended...
that would fine enough...
OR
like me...i'm using diesel engine oil in petrol car...its really clean internally
leinnz
333
57
3,028
OR
wow. car wont be heavy ar using Diesel EO
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
as heavy as lorry... :rofl:
nope.. works just fine...
not only on 1 car... but multiple car i currently own...non turbo and turbo...normal daily drive and weekend fast drive...
key is always keep oil at good level and oil change interval dont drag longer than recommended...(shorter is better..just dont too short like u did)..that is a big waste
ixeo
4,788
3,080
KL, Malaysia
Don’t bother.
If really want to do it, buy cheap single grade oil SAE30 to flush then refill with your normal FS
parakey
1,367
226
663
What's the point and what do you hope to achieve? Recalibrating the butt dyno? Bear in the mind that the filter which you choose not to replace, contains a fair amount of tainted oil.
leinnz
333
57
3,028
okok. thanks for all inputs, looks that regular change intervals / maintenance is the best.
Thanks
leinnz
333
57
3,028
Out of curiosity, did you open the oil filler cap and see a lot of muck, sludge or varnish in the engine?
varnish yes.sludge mild
damn!!....what the F**K!! my car got smashed at the drivers door glass and my rsm and turbo timer is gone. blardy f**kers!! it happened like around 8-9am in the morning. my hsemate who went out at about 8am said there was nothing at that time..when he fetch his sis to mid valley and then back....gone! saw my car wind shield smashed liao...........happened at my HOUSE!!! DAMN!!! house at ss2/81, the taman opposite ss2 murni. i just hope those low class assholes will die a damn painfull...
