Check engine
acinatas
Mar 28, 2011
5
Hai fellow ZTH,
Im using FN2r. Recently ive changed my air filter to simota air filter. Then the check engine appears. Ive dismantled the battery and hoping the ECU can adjust to the new air fuel ratio. At first it was ok. Then the check engine appears back. I havent tried changing to the OEM air filter yet.
My question is the ECU cant adjust to the new breath ? Do i have to use Hondata or equivalent?
Thanks,
Newby in I-vtec
---------- Post added at 04:40 PM ---------- 6 hour anti-bump limit - Previous post was at 04:37 PM ----------
Sorry, Forgot to mentioned, there's no fault in the engine. everything seems normal.
D7zul
2,697
848
Shah Alam
did u unplug any sensor on the airbox when u change it?
Hi sifus out there,
I am currently facing a problem here, I have bought a mazda B8T 210 engine and it is in the midst of transfering it into my mazda astina.
The problem now is, the mechanic is facing a problem to help me lock the by welding the gearbox in order to become a 2wd. He has send to some machining shop but he told me its gonna leak and wont last long. So he say better source for TX3 or a b6 gb.
Please Please Please helppppp! Its been 3 months already.:dontknow:
